Alternator/Valve Cover Clearance
Old Sep 18, 2007 | 07:28 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I'm almost done with my engine swap, however I ran into a small problem last night. The battery post on my alternator hits my aluminum valve covers. I cut the post down enough to get the valve cover to bolt up, however it either touches or barely clears it. I know it will arc over when I crank it. I've read only two threads about this and no real answer besides new valve covers (not an option) and trying to rotate the clock which I haven't tried yet ( and doesnt seem to work for most people). I could possibly cut the post down some more, but it would require removing the nut that acts as the seat for the wire. Any suggestions? This is for a serpentine belt system
Old Sep 18, 2007 | 07:54 AM
Re: Alternator/Valve Cover Clearance
new valve covers
Too bad it's not an option... sucks to have some kind of valve covers you like, all ruined by a car that doesn't work...
Get some valve covers that actually fit. You'll be MUCH happier in the long run. Sell the ones that don't to the "greater fool"; trust me, there's ALWAYS one out there.
Old Sep 18, 2007 | 08:32 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
I doubt there are any tall valve covers out there that would work. These are even recessed somewhat.
What if I had a piece of rubber between the post and the valve cover. Surely someone has ran into this before. I do recall there being a plastic cover over the post when i pulled the old engine off. It wouldn't be able to arc through the plastic cover or so I wouldn't think.
Old Sep 18, 2007 | 11:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll eventually wear through the rubber and be in the same situation.
Old Sep 18, 2007 | 12:39 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Thats only if the stud touches the rubber. If there is a gap it should be fine. Even if there a gap without the rubber it'll arc if its too close. I'll think of something over the next few days and post my solution.
Old Sep 18, 2007 | 12:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It won't arc unless it touches. You need something like 1000 volts DC to arc across a .005" air gap.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
New2Chevy
Sep 28, 2015 12:35 AM
codeysabatini
Sep 20, 2015 11:36 AM
355tpipickup
Sep 13, 2015 11:35 PM
