tpi 350 swap
Old Sep 19, 2007 | 02:39 PM
glock240z's Avatar
tpi 350 swap
hello to everyone,.
i dont know where to turn. im doing a engine swap on my 63"truck, im putting a 350 tpi engine of a 88' camaro irocz.my problem is that i dont have the ignition or the key and alot of people told me that i need that to start the engine due to the fact that the key has a chip.is there any way to bypass it?
i tryed to start the engine and it wouldnt start.the engine was running before i pulled it out of the camaro.
Old Sep 19, 2007 | 02:54 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: tpi 350 swap
Yes you can bypass it, it the vats system that needs to be turned off.
You can get a new chip burnt w a performance tune and no vats, or buy the bypass module from painless wiring. I would burn a new chip for the performance (about $100) or the modual for 60 or so.
Old Sep 19, 2007 | 03:22 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: tpi 350 swap
Here's a site you might find useful. I have...
http://www.chevythunder.com
What are you using for your harnesses?
Good luckwith the swap!
Old Sep 19, 2007 | 03:31 PM
glock240z's Avatar
Re: tpi 350 swap
what is the vats?
do you mean take it to a shop an get the ecm program to turn off the vats?
if i burn a chip does that mean i could use switch to turn on the motor or do i still need the ignition & key?
im running the stock harness.
Old Sep 20, 2007 | 11:54 AM
socal's Avatar
Re: tpi 350 swap
vats is (Vehical Anti Theft System) on gm vehicals
if the vats is turned off in the prom there is no need for a special key any swich (key) will work. There is nothing you can take to a shop to turn off its just the prom (chip) in the ecm.
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
