383
Old Sep 22, 2007 | 06:16 PM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Transmission: automatic
Axle/Gears: stock
383
im looking to build an 383 for my 86 iroc with a tpi . can anybody give me some pointers on what i should build it with to make it still work with the tpi setup or what i would have to change on the tpi to make it all work together. im looking to make about 400 hp from it so any one with some info would really help
Old Sep 22, 2007 | 06:47 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 383
first , welcome to the forum . search the eng. forum and you will find all sorts of ideas and help .
Old Sep 23, 2007 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ditto the welcome.
TPI will severely restrict a 400 HP 383. Figure on completely replacing all of the hardware, as the base & runners simply aren't up to the task. Super Ram, Steath Ram, or Miniram are about the only way to support it.
Old Sep 23, 2007 | 05:48 PM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Axle/Gears: stock
Re: 383
so if i change ut te runners and the base will i still be able to use it or should i just go with the new stealth ram stuff
Old Sep 23, 2007 | 09:44 PM
five7kid's Avatar
Aftermarket base & runners, and ported plenum will help, but will still fall short.
Old Sep 24, 2007 | 12:06 AM
mxthreat's Avatar
Car: 86 iroc
Engine: 383
Axle/Gears: stock
Re: 383
good to know is there any thing eles i should know? last t ime i did this was on a 82 z28 with a carburator and the car was an original crossfire fuel injection set up and no one would smog it
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
