L31-R!!
Old Sep 25, 2007 | 10:22 AM
iroc192's Avatar
L31-R!!
Ok guys check this out.What do you think? What cam should I go for?(Looking for mild-ish with more vroom vroom) Everything looks pretty sweet, me and my dad have looked it over, no marring or scratching and everything measures right, walls and all.I'm very excited and I think this motor will do well supposed to be 255hp and 350 torque in the trucks they put it in, i'm open to any mods.It's gen 1 style block so I shouldnt have any problems with my flywheel on 700r4?Let me know what you think! I'm taking suggestions for everything! Oh yeah, keep in mind it's slight budget build. heh.http://www.jegs.com/webapp/wcs/store...-1&showValue=2
Old Sep 25, 2007 | 10:37 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: L31-R!!
That's a pretty decent route to go. The vortec heads are good and it's a roller block. With a cam you could make decent power.
What year is your car? That will determine if your flexplate will work. (manual transmissions have flywheels)
Old Sep 25, 2007 | 11:20 AM
iroc192's Avatar
Re: L31-R!!
1989 IROC camaro. the blue one on your left remember, the l31-r is a gen1 block ;D
Old Sep 25, 2007 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your '89 flexplate will work with the L31.
"Gen I" doesn't mean your flexplate will work. '55-'85 were "Gen I", but a flexplate from them won't fit the L31.
Old Sep 25, 2007 | 01:30 PM
Engine: 400
Re: L31-R!!
In 1986 Chevy changed the rear main seal to a one piece design. So any blocks from 1986 and later will need a one piece main seal flywheel/flexplate. Blocks that are 85 and older will need a TWO piece main seal flywheel flexplate. (Even though they are all Gen I's) Good luck.
bluedart
Aug 15, 2021 10:42 AM
SilverChicken
May 27, 2015 02:06 PM
85irocz28driver
Apr 9, 2015 01:53 PM
davidGTA
Jul 16, 2010 09:37 PM
