TBI to Carb throttle cable
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Seems like the search function is down so Ill just post a couple quick questions I have. In the process of wrapping up a tbi to carb conversion and am trying to figure out what cables Ill need. I know one cable is the carb throttle cable which is shorter than the tbi cable, but I can seem to find it on ebay or any of the sites sponsors. ANy ideas where to find it? Also isnt there one more cable I need for this swap? Whats the name of it?
Steven
Steven
Transmission: 4L80E/4L80E
Haven't done it myself, but I was under the impression that you could use the TBI cable on a carb. It's TPI that's longer.
But, I could be wrong.
The other cable is the throttle valve or "TV" cable to the transmission.
And cruise control cable if you have it.
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Re: TBI to Carb throttle cable
I used both stock cables (throttle and TV) when I swapped my tbi to 355 carb w/o any problems on my last 3rd gen.
Car: 87 camaro/73 Mustang
Engine: 350/351C
Transmission: T-5/C6
Axle/Gears: 2.73 Posi
I also Swaped to a holley vs. tpi. no problems, used both tpi cables. Might need different mounting brackets to get them adjusted to your likings.
Car: 92 camaro,99 s10
don't mean to jack a thread but I'm going from MPFI v6 to carb 350. and i was wondering if i can use a universal cable to make it work. something like a spectre?
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
