carb to TPI
Old Sep 28, 2007 | 07:53 PM
yaretheytaken's Avatar
Car: 92 RS
Engine: 350 Carb'd (almost TPI)
Transmission: 700R4 (soon a T-5)
Axle/Gears: 3.23's
carb to TPI
I have a 92 Camaro RS with a 73 350 chevy carbureted. I would like to convert it to TPI. What I would like to know is will the tpi intake bolt up to my heads. Also will the sensors be compatible with my motor. I know that I will also need a computer and wiring harness. My other concern is will there be a noticable power increase. I am sure that I will get better throttle response and well as better fuel economy. Any information will be greatly appreciated.
Thanks,
John
Old Sep 28, 2007 | 08:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
'85-'86 TPI base will bolt to your heads (assuming you have '73 heads on the 350). '87-'92 will if you modify the center two mount bolt holes on each side of the base to be the same angle as the rest.
Power will not increase, assuming you have the carb set up half-way decent now. Throttle response and economy will most likely increase. What you have to modify depends highly upon what how complete a TPI setup you get.
Old Sep 28, 2007 | 08:30 PM
Car: 92 RS
Axle/Gears: 3.23's
Re: carb to TPI
Let's assume the TPI setup that I get is as complete as possible what sensors would I need and what would I have to modify? Also on a scale of 1-10 how hard do you think it would be to hook up the computer and wire everything?
Old Oct 4, 2007 | 11:32 PM
stingray's Avatar
Car: 1976 Corvette Stingray
Engine: LB9 TPI- Want to go bigger!
Transmission: TH700R4
Axle/Gears: 3.08
Re: carb to TPI
I'd also add reliability and less frequent maintenance to that list of advantages of TPI.
One thing I've wondered is where would you put the knock sensor on a motor that didnt originally come with one?
O2 sensor is easy, an exhaust shop could weld a bung in for one in a few mins.
You'd have to get a high pressure (electric) fuel pump as well.
When I swapped in a TPI motor (complete) into my 76 vette, I sent out the TPI harness to a company in TX that did the modifications for me. Worked great.
You'd also have to swap out the air box/snorkel, but that shouldnt be a problem.
Old Oct 4, 2007 | 11:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: carb to TPI
The block should still have a "drain hole" on both sides of the engine in the bottom center at the oil pan rail. Remove one of the drain plugs (stock is the passenger side) and install the knock sensor.
See the tech article on this site about swapping from TBI to TPI, it will give you an idea of where to start. If you dont have any electronics or mechanical experience, this will be a difficult job.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
