Short Block Build up. What to do?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys I've got a few questions. I've got an 880 bare block (same used in the ZZ4 motor) at home and I think it's time to start throwing it together. I know that all the power lies in the heads, cam and intake but I want a short block that will withstand atleast 350 to 400 horses. What are some good yet not overpriced options for me? I would also like to hit it with alittle nitrous (125 shot maybe) What can I do? I'm more than likely going with some 170cc E-tec's and a good intake and cam to match it up for the top end.
Transmission: 4L80E/4L80E
Steel crank, most any aftermarket rod with ARP bolts, forged pistons.
Gap the rings for the shot.
Re: Short Block Build up. What to do?
sounds like a plan, what is a good crank to use? eagle, scat or ZZ4 steel crank?
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
if your goig to buy a need crank, get a stroker one, their a cheap up grae and then u can step up to the bigger heads and cam and not worry about drivablity, and the upgraded cam and heads wont be much more then the ones you are plannin on gettin now,
here are a few parts thatd id look at if i were buildin a SBC
http://www.jegs.com/webapp/wcs/store...63943_-1_10759
http://www.jegs.com/webapp/wcs/store...46700_-1_10187
http://www.jegs.com/webapp/wcs/store...-1&showValue=2
then just a good dual plane manifold and i think ud be set
