bbc swap question
Old Oct 10, 2007 | 02:34 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
bbc swap question
I am going to be starting a bb swap in the near future so the 406 shortblock and 700r4 will be up for sale soon. But anyway I am going to be using a 454 and boring .060" and 4.250" crank (496) and wanted to know which block is better? I was thinking about just finding a gen IV block and then I saw there were some gen VI blocks that are 1 piece rear seal and came with roller cams and had the fuel pump boss. Are most of you guys running hyd roller cams or solid? did the later gen IV motors use a roller cam from the factory or did that start with the gen V?
Old Oct 10, 2007 | 03:46 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
Re: bbc swap question
a couple months ago hot rod did a build up of the new 8.1 liter bbc... they put afr heads andstuff on it and cranked out i wanna say just over 700 hp on the stock short block... ill look and see if i can find the article...
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
