v6 to v8 swap?
v6 to v8 swap?
Hi, Im looking to do an engine swap in my '88 Camaro RS from the 2.8 V6 to a V8. Most likely a 350. What I am asking though, is how much is actually involved and how much momey could i expect to pay to do the swap?
Also, about the motor mounts, am I going to have to change the mounts as well? Please help with ANY information you have...THANK YOU!
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
Start by reading through the sticky in the top section of this forum. https://www.thirdgen.org/forums/engi...swap-read.html
Cost - well, that varies too much to be able to give you much meaningful information there. Usually, it'll cost a lot more than the increase of the value of your car. And that's assuming you do all of the work yourself.
Hello, Michael
Aug 20, 2015 03:19 PM
