Going from CCQjet to tpi
Old Oct 22, 2007 | 12:03 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I have an '86 IROCZ with a 305 CC QJet and T-5, I'm wondering if i have to have the computer changed so i can use it for a manual trans?? The motor is out of a 88 iroc. Its a 305 Tpi. I have everything i need but i'm wondering if i need to have the computer reprogrammed since its currently programmed for an auto. I'm new to swapping motors as well so if anyone can give me any advice that will help me out please feel free to put in your 2 cents.
thanks
Old Oct 22, 2007 | 12:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The engine control programming isn't affected by the type of transmission. The only signal the auto ECM would send is the torque converter clutch lock-up, and since all it does is ground a circuit that doesn't exist with a T5, no problems would result. It also wouldn't get the "4th gear" signal from the tranny, but all that does is say it's okay to lock up the TCC.
Old Oct 23, 2007 | 07:35 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Re: Going from CCQjet to tpi
Thanks for your input on that. Is there any tips you can give me on swapping the engines?? any pointers??? i've never swapped an engine before.
Old Oct 23, 2007 | 08:34 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
ACTUALLY, the Fuel, Ignition timing, and IAC programming between transmissions is VERY different. The automatic transmission places a different load on the engine than a standard does at different times.
Old Oct 23, 2007 | 10:58 PM
86irocu's Avatar
Car: 1986 Iroc-Z
So i will have to get it tuned??
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
