brake line/motor mount
Old Oct 31, 2007 | 07:35 AM
fastregalwe2's Avatar
I bought an 89 RS (former V6) roller and went to put in the V8 mount stands on the frame and the brake line comes over the top of the engine cradle right where it LOOKS like the cradles bolt up. Anyone have a pic of the motor mount location for the V8 and do I need to swap that brake line?
Old Oct 31, 2007 | 08:16 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: brake line/motor mount
Motor mounts for the V8 goes in the front set of holes. You can move the brake line back for the mounts to work.
Old Oct 31, 2007 | 09:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's what I did.
I believe that is covered in the V6 to V8 sticky in the top section of this forum as well.
Old Oct 31, 2007 | 12:07 PM
thanks
I read and saved the sticky, guess I skimmed a little too fast cause I dont recall seeing that.
Old Oct 31, 2007 | 01:05 PM
five7kid's Avatar
From #11:
"The right/front brake line mounts to the front of the crossmember for the V6, right where the V8 mounts need to go. Either use the V8 factory line, or carefully bend the line to the rear of the crossmember after the mounts are removed from the V6 position. The p-clamp mount holes are there for the V8 position for this line. Side note: '82-'84 used SAE-type brake fittings, '85-up used metric."
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Eric-86sc
Apr 3, 2016 03:52 PM
