LT1 swap considering it
Old Nov 15, 2007 | 07:49 PM
1985z28FordKila's Avatar
ok tell me every tihng i would need for an lt1 swap in to my 89 formula
well givens are LT1 haa and wiring harness, fuel pump, comp+ what else i am looking for every god forsaken tihng i would need so i dont run i nto bull ****.
oh and would my exsisting 700r4 4 spd auto bolt up to an lt1??
Old Nov 15, 2007 | 10:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you read the LT1 swap stickies?
Old Nov 15, 2007 | 11:11 PM
Re: LT1 swap considering it
yes i did but i just wanted like the hardfacts cause there is alot of in jsut way to spread out for me wit hdiffrent suggestions and stuff to me is jsut seems hard to follow
Old Nov 16, 2007 | 12:39 AM
five7kid's Avatar
Most people look for a complete engine drop-out from a Camaro/Firebird including engine, computer, and harnessing. Many I looked at (before deciding on the LS1) included the transmission as well. The cooling system is reverse flow, the LT1 radiator simplifies things a little bit.
Your TH700 will bolt up to the LT1, but '93 was the only year the throttle body included the TV cable. One member worked around that (check out the subforum). Using the 4L60E that came on '94-up LT1's isn't a bad idea, as the PCM controls it and is easy to reprogram, and it's a little bit of an upgrade from the TH700.
Fuel pump - Walbro 255 is very popular around here.
Wiring - see the stickies.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
