swapping out my 5 speed for an auto
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: swapping out my 5 speed for an auto
brake pedel set-up for the automatic, tranny obviously, shifter, shifer cable, some sort of release (i'm assuming optional) through the steering wheel so that brake has to be depressed and car need to be in "on" to shift, and a slew of sensors and possibly a harness, a park/nuetral switch that may come on the shifter you find is just a couple of the things that you will need.
BTW you will probably get yelled at cause this is a third gen site, but this should be a round about start to your project, good luck!
1992 Trans Am
Aug 8, 2015 08:16 PM
