02 5.3 vortec in camaro
Old Nov 19, 2007 | 04:56 PM
88z28350's Avatar
Has anyone done this? Put a 5.3 in an 88 camaro z28? I have a good connection to get a 5.3 but dont wanna waste time if its not a direct swap out.
Old Nov 19, 2007 | 05:43 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 02 5.3 vortec in camaro
5.3 would be like swapping an LS1 in the car. Plus you would have to run the LS1 accessories, waterpump intake and f-body oil pan. Probably be easier to use an LS1 wiring harness and PCM as well. Sounds like a pain, but will make more power in the long run than any 1st gen or 2nd gen SBC or an LT1 as well.
Old Nov 19, 2007 | 05:54 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Yeah, basically the same as the LS1 swap described in the engine swap sticky...
Old Nov 19, 2007 | 06:31 PM
88z28350's Avatar
oh ok, sounds good. Basically the LS1 would be to expensive for me to do so i was wondering about that since i can get a 5.3 fairly cheap. But i didn't wanna be really down grading or doing something that will just be a waste of time and money. So what transmission would i have to go with? it has a 700 right now with a carb350
Old Nov 19, 2007 | 08:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, some 5.3 engines can be bored to 3.90", same as the 5.7 LS1. Use LS1 pistons in there and the 5.3 heads and you'll have a nice 11:1 iron block 5.7 LS engine
Old Nov 20, 2007 | 07:41 AM
Klortho's Avatar
Car: 1987 GTA
Ditch the 700 and get a 4L60E from an f-body, with that the PCM and f-body harness, you'll be setup.
84z96L31vortec
Aug 20, 2017 12:16 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
