how to start new forum???
Old Nov 18, 2007 | 01:03 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
ok so i just joined thirdgen and i need some insight about the motor swap i will be doing soon and need want to ask some questions and i cant figure this damn thing out, will somebody please tell me where to go, thanks.
Old Nov 18, 2007 | 01:57 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: how to start new forum???
well... since you already created a topic you can ask a question here
Old Nov 18, 2007 | 02:01 PM
brodysZ28's Avatar
Engine: 383
ok, so im pulling the stock L69 out of my 83 Z28 and I have a 350 that is coming out of a 89 gmc jimmy, it isn't the stock engine tho, im pretty sure that it is a gm performance parts motor. That motor should bolt up to my 5 speed tranny right? is there any problems with this swap that I should know about?
Old Nov 18, 2007 | 02:26 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
The 87 and up small blocks with a one piece rear main seal use a different flywheel than the 86 and older engines with the two piece rear main seal.
I guess you should check that first.
Next, you need a flywheel for an 82-92 Camaro for the style of engine you are running. For example if you have a newer style engine, then you need a flywheel and clutch kit for an 87-92 Camaro with a 305 5 speed. If you have the older style engine then you can use your old 305 stuff. Everything will bolt up fine if you do the flywheel part right.
Welcome aboard!
Old Nov 18, 2007 | 03:01 PM
brodysZ28's Avatar
Engine: 383
so if this 350 is a one piece rear main than I cant use my clutch and flywheel from the 305? I've got a Zoom high perf. clutch in it now.
Old Nov 18, 2007 | 03:48 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
You can probably use the clutch but not the flywheel.
Old Nov 18, 2007 | 05:01 PM
brodysZ28's Avatar
Engine: 383
so for it to work i need to use the flywheel from the 350 and the clutch should still work?
Old Nov 18, 2007 | 05:09 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
yep
Old Nov 18, 2007 | 06:19 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
You can use the "flywheel" as long as the truck 350 has the small clutch manual tranny. Otherwise, you will need the 87-up 153 tooth small flywheel. Some of the trucks came with the 12 inch clutch setup that has a 168 tooth flywheel.
Kevin
Old Nov 20, 2007 | 07:19 AM
brodysZ28's Avatar
Engine: 383
the 350 is coming out of an automatic, so I have to get a 87 up 153 tooth small flywheel? would I have to get a dif starter or anything else to go with that? will my clutch be compatible with that?
Old Nov 20, 2007 | 10:45 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The first thing you need to do is find out exactly what type of engine it is. If the original engine has been replaced, it could be most anything. Replacement using an older engine type is pretty common, especially if it was a cheap GM Goodwrench replacement engine (more likely than GMPP, I would say). It could be 2-piece rear main seal, in which case your 305 stuff would bolt right on to it.
You will need to install a pilot bearing. Just getting a new one would be easier and make a lot more sense than trying to pull the existing one out of your 305 crank and reusing it.
If the 350 is one-piece rear main seal, then get an '86-'92 Camaro/Firebird V8 flywheel. It will be 153-tooth, and your 305 starter will work on it just fine.
Don't forget the pilot bearing.
Old Nov 20, 2007 | 03:10 PM
brodysZ28's Avatar
Engine: 383
ya that does sound familiar now that it is a goodwrench motor, i knew that it was gm,i can't be sure tho until the motor is out. I am checking the compression in it soon then pulling it out.
Thanks, Brody
eightsixseven
Dec 16, 2024 01:50 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
hokis
Aug 9, 2015 03:57 PM
