COMPLETE WIRE SWAP TO 95LT1
Old Nov 23, 2007 | 11:56 PM
joshuasmith580's Avatar
I HAVE A COMPLETE WIRING HARNESS FROM 95 FIREBIRD HEADLIGHTS TO TAIL LIGHTS WITH LT1 FOR MY 86 T/A HAS ANYONE EVER TRIED A SWAP LIKE THIS ONE ??? AND CAN I USE A FRONT END OUT OF A 95 ON A 86 OR THE ANTI LOCK BRAKES WITH MY 4 WHEEL DISKS THAT ARE ON THE 86
ANY TIPS WOULD BE GREATLY APPRECIATED
Old Nov 24, 2007 | 08:36 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: COMPLETE WIRE SWAP TO 95LT1
Anything is possible, but why goto that much of a hassle?
No, the front suspension pieces will not work on a 3rd gen, it's a rack and pinion setup instead of steering box and the front spindles are different as well and they won't bolt up either.
Old Nov 24, 2007 | 03:27 PM
is there any chance in using the anti lock electronics and sensors with my four wheel disc brakes on the third gen or should i just change to the lt1 without the brake system
Old Nov 24, 2007 | 03:44 PM
Klortho's Avatar
Car: 1987 GTA
just put the motor and tranny in using the f-body engine harness, you can't put the ABS stuff in a 3rd gen, nobody makes rotors that have the reluctor ring in them.
Old Nov 24, 2007 | 10:07 PM
thanks for the info
Old Nov 24, 2007 | 10:20 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The reluctor rings aren't the problem. S10s use the same rotor with rings. The problem is the wheel sensor. Mounting it is where people tend to give up. It was discussed at length a few years ago and deemed too much trouble. That would be a whole lot of work to change all of the wiring. I belive someone did it with an LS1 swap.
Jorlain
Aug 24, 2022 05:11 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
