LT1 SWAP QUESTION
Old Dec 19, 2007 | 10:14 PM
1985z28FordKila's Avatar
LT1 SWAP QUESTION
um ok i was crusin round town in my 305 camaro dreaming bout the lt1 motor swap. and then i thoguth of limited speed. if i do the lt1 swap will my speed be limited? and if it is how umm do i "fix" the problem of the lt1's limited. speed jsut some one help me plz with this simple question
Old Dec 19, 2007 | 10:51 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: LT1 SWAP QUESTION
Umm........
What the hell are you talking about? Do you mean the speed limiter in the ECM? I hate to break it to you, but your 305 Camaro should have had that as well...
Anyway, if you ARE talking about the ECM speed limiter, you can disable that by custom ECM tuning on the DIY PROM section. I'm sure they'll show you how.
Or, maybe you're talking about the fact that it won't let you shift through all of the gears unless you're at full throttle?
Anyway, your post confused the f@#$ out of me...
Old Dec 19, 2007 | 11:14 PM
Originally Posted by KrisW
Umm........
ok haha yea i was a little mad at the comp it was messing up. but yea The ecm limits my speed. i am goign to do a lt1 swap in to my firebird. and i wanted to know if the lt1's ecm is going to have a speed limiter like the 305 and. it does apparently, soo were the hell would i get that reprograming stuff u can help me out.
and sry yea my post was very stupid aha but thnakx for answering hope that clarifies waht i am tryign to ask
Old Dec 20, 2007 | 06:24 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you get an LT1 PCM from an f-body or vette I think the speed limiter was set at 255mph from what I remember from reading mine. As for the skipshift if that makes you shift from 1st to 4th when low rpms that can be taken out of the PCM.
You can always flash the PCM's to whatever you want to (if you get a '94+ PCM, stay away from the '93s)
Old Dec 20, 2007 | 09:09 AM
ok so i got really notihng to worry about cause if the speed is limited to 255mph. i do not think ill be going that fast haha
Old Dec 20, 2007 | 02:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Cars with the Z rated tire option got no speed limiter and the 150 MPH speedometer, without the option you got 115 MPH speedometer or so and a limiter.
Old Dec 20, 2007 | 09:55 PM
ok how can i look for this option via vin number. and spedo. and if i cannot find one i can jsut reprogram the ecm or soem trihng to by pass the limitatation
Old Dec 24, 2007 | 09:31 PM
BryceShular's Avatar
hey whats up i know im in the wrong forum ...or generation i should say ... but im currently doing a lt1 engine swap ... in a 81 camaro ... and i got a 94 lt1 out of a z28 ... would any one here know any thign to help me out here .. if so please reply ... thanks
Old Dec 25, 2007 | 11:54 AM
well waht is the problem
Old Dec 25, 2007 | 11:05 PM
im needing to know how to wire it in ... and what all wires i would need... i seen the wiring diagrams in othe rpost for the lt1 ... but how about for the 81 .. just basiks im new to this style engine ..
Old Dec 26, 2007 | 12:16 AM
try http://www.speartech.com/
they may have some thin
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
