traction bar question
Car: 92 Z28 camaro
Engine: 406 stroker
Transmission: built T350
Axle/Gears: 4.10's
Hi i got a question for all you guys. iv got a 92 Z28 camaro that came with the 350 TPI i did a motor swap and now have a 406 small block with a built 350 tranny. my question is dos any one have any good ideas on how to reattach the stock traction bar from the diff. to the tranny? my 350 tranny is about 6 in. shorter than the stock 700R4 so the bar dos not reach the tranny and the tranny dosen't have any bolting holes for that bar. any suggestions?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: traction bar question
Spohn Performance http://www.spohn1.com/?action=product&pid=1128
or
UMI http://www.umiperformance.com/2214?category_id=114
Buy a good crossmember mounted torque arm. Its a bolt in deal and will greatly help traction.
I personally am a fan of UMI
or
Car: 86 Trans Am
not cheap by any means, but they are the way to go. also b&m and hurst sell conversion kits for this situation, about 100bux, check out jegs or summit. I would still recommend the UMI or Spohn pieces. You will be happy you did. I think UMI has a sale right now in the suspension section 10%off through the new years or something
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
I got full Spohn chassis in my 87.... lays down a 1.31 60' and have never had a problem!!!
Do it right the 1st time, so you dont have to spend more money after you break the cheap fix
ProtoMaster22
Aug 26, 2015 07:50 AM
