What's the magic of LTx or LSx versus any other pushrod V8??
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What's the magic of LTx or LSx versus any other pushrod V8??
my favorite test was a 406 smally put up against a 402 lsx of some sort, think ls2 based.
both made similar power but i dont have the article hear for detailed specs. i want to say the 406 was a hot combo while the lsx 402 was abit more conservative as far as cam specs went. i'll have to dig that article up.
i think hp was around 560 for both on crank that is. i know a 402 lsx is capable of 500whp so thats close to 580 on motor i'd say with a T56
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there is some talk about the hp per dollar the lt1 vs the ls1 but it seems like the patriot cam/head kits got overlooked. and are priced just over a grand and up.
so far I don't see any lt1 kit in similar standing making anything close to what these ported stock head/ cam kits produce hp/dollar wise
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Most all "old school" production V8's suffer from the exhaust ports being too low on the head. Fords are the worst. A 351C-4V head has intake ports that flow more than a square port BB chevy and exhaust ports that flow much less than any SB chevy-even though they have a lot of volume.
Earl Wade was the designer of that deal. Then they had to work on the oiling system because the lower end couldn't hold up to the power.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
425 RWHP by several of the online calculators should get you a mid 11 sec at 118 mph pass @ 3300 lbs, which isnt exactly hard to do with an LT1 while retaining a/c, ps, etc.
This is something that realistically consists of a $1000 LT1/auto, or 1800-2400 LT1/T56, $2k for ported heads and cam. Injectors, rockers and a tune, with supporting exhaust of course.
Engine: ls1, LB9
You arent taking into account the cost of the engine / trans and installation parts. For anything sub 430 RWHP, chances are the LT1 is gonna cost less.
I think just about all of us can agree the lt1 is the cheapest vs best bang for the buck in stock and lightly modded hp
Car: 93 240SX
Engine: LQ9
It may cost you a bit less to get a set of ported heads for the LS1 yes, however its going to cost you more for the engine itself, the trans, the required installation parts, and then for each of the supporting mods to install said parts, installing the heads / cam on an LS1 vs LT1 you're going to spend a lot less on rockers for the LT1.
Engine: 2.8/TBI/TPI
While working on my 4.8 LS, I noticed something else I really like. This engine uses an old style 13/16 BOP oil filter! I actually had a PF61 Delco for one of my older Buick engines and I had a smile I couldn't erase for the rest of the day. It was also nice to see the oil pan scooped out with a nice, protected area for my filter. The PF61 was longer than the OE that I took off, but so what? The PF 61 fits in there like it was made for it.
The oil filter and the aluminum pan are two more pluses for the LS engine, in my opinion.
Do they use that aluminum pan for extra block rigidity?
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Pretty much it's the same oil pan for all of the LS based engines just different depths since the LS1 came first and was all aluminum guess to keep tooling costs down.
