oil pan question, 305 to 350 swap
Old Jan 21, 2008 | 09:42 PM
TheMutt's Avatar
swapping from 305 tpi to older 350 and was wondering if I was going to have clearance issues with the 350's factory oil pan. I was wondering because I notice JEGS and SUMMIT have oil pans specifically for third gens, makes me think that a stock old pan wont work for some reason.
Old Jan 21, 2008 | 10:02 PM
Elephantismo's Avatar
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
Re: oil pan question, 305 to 350 swap
Externally, they are pretty much the same in dimensions. The difference between new and old is...
New:
dipstick on left side (from the front of the motor)
Additional partial windage tray and the lowest center point is re contoured (to provide more structural support?)
Old:
Opposite side for the dip stick.
The end seals may also be slightly different sizes. The pans will not be interchangeable between motors if i remember correctly. There could also be some specific applications that vary
Your old oil pan on the older style 350 should be fine fitting into the car.
Old Jan 21, 2008 | 10:20 PM
TheMutt's Avatar
i know the pans between the two blocks will not interchange due to the whole seal and dipstick issues, but I was just wondering about external fitment I guess.
thanks a lot!
B_Dubya
Aug 26, 2015 05:09 PM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
