serpentine belt drive to a real old 3.8 turbo
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
Just curious if a GN or TTA serpentine set would bolt to my 1980 3.8 .... or maybe a later model 3.8 ..... Look at my camaro's 3.8 but not much looks the same. So what do you think about these later 3.8 stuff working on mine or am I destined to keep the V-belts.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: serpentine belt drive to a real old 3.8 turbo
You can use the GN/TTA setup if you run the matching water pump. It turns the other way. If you don't use it you overheat all the time.
None of the front wheel drive stuff works because the crank pulley and timing cover are different. The 4th gens are using the front wheel drive engine with a different intake.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
mcquigg
Aug 13, 2015 02:26 PM
db057
Aug 11, 2015 10:11 PM
