Swap 2.8 to 383 carb
Old Feb 5, 2008 | 11:19 PM
xyzman's Avatar
Want to know everything to swap a 383 carb into a now 2.8 1985 auto trans camaro tnx xyz
Old Feb 6, 2008 | 12:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Read the V6 to V8 swap sticky in the top section of this forum.
Read the tech article about going from EFI to carb linked from the thirdgen.org homepage.
Search this and the Tech Forum for info about building 383.
Old Feb 6, 2008 | 12:41 AM
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
Re: Swap 2.8 to 383 carb
Before even dropping a 383 in beef the living hell out of your suspention... first of all as the stickie about v6-v8 swaps said on the very last line the v6 suspension will bottom out with a v8... and evenb befor thta if u keep stock chassis components with a 383 stroker motor even with dished piustons and a crap cam they produce too muchb low end torque for our cars. in 2 summers of driving ull have cracked windsheild and your doors wont shut right... id invest in some kind of ajustable torque arm (spohn from what i hear is good but the jegster ajustable has great rationgs for all around use) better rear shocks (ajustable if possible) panhards and stronger rear sway bars and bushings... after that is out of the way. if you plan to keep the feul pump in the gas tank get a feul pressure regulator (holly makes one for like 60 bucks) 75 psi from the efi pump is wayyy too much for your carb reduce that to around 8-10 depending on your carb and what your gonna do with the car. if not just drop teh tank and remove the feul pump... at this point ill leave it to others to help you out
Old Feb 6, 2008 | 01:15 AM
Crux's Avatar
Car: 1987 Camaro
Engine: V6 2.8L
Axle/Gears: stock?
And people wonder why I don't "just throw in a 350" to replace my 173(v6 2.8)...
midge54
Jan 29, 2017 07:00 PM
Cameeeero
Sep 18, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
