305 to 350 timing question
Old Feb 8, 2008 | 04:17 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
Hey guys im almost done with my swap from the 305 carb to my 350 carb, i had a question tho about the timeing. i used all the accesories from my 305 on the 350 including sensors.. what should the timeing be at, i kniow the 305 is 6 and the 350 is 8.. but i wanna make sure which i should put it at if either of them at all? and my check engine light is on... i didnt know this car had a computer any reasons u can think of why i would go on after a new swap... or is it cuz the timeings off?
Old Feb 8, 2008 | 04:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 timing question
Setting it at 6 or 8 would be a start, you can add more if the engine tolerates it.
What codes are being set by the check engine light?
Old Feb 8, 2008 | 05:13 PM
fychelio's Avatar
Axle/Gears: ????
good question... do i do it the same as my old supra i stick a paper clip in the t and t2 slots and put the ignition in ac to check the codes?
Old Feb 8, 2008 | 05:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's similar, the paperclip goes in the top left two terminals in the ALDL connector under the dash and you turn the ignition to "on" (but not start). I don't know for sure if that'll work with an 83 though, some of the early computers were pretty crude.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
