Casting Number Question?
Old Feb 25, 2008 | 05:03 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
I have a 350 block with the casting number 14093638. I want to get a hydraulic roller cam without having to buy the retro style cam and spending an extra $500 on the mod. heres what mortec says about the block
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
It is a 4 bolt main with a 1 piece rear main, so can i buy a hydraulic roller cam without having to buy different pushrods and the retro style?
Please help!
Old Feb 25, 2008 | 05:06 PM
ljnowell's Avatar
Re: Casting Number Question?
Please help!
Look in the lifter valley. On top of the hump in the middle where the cam is, are there any holes that are threaded? I so , look at the front of the block, is there holes for a cam retainer plate to bolt to? if so, yes it is ready for a roller. If not, you can make it ready for a roller.
Old Feb 25, 2008 | 10:14 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
any way i could see a picture?
Old Feb 25, 2008 | 10:19 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
actually im pretty sure that your block is a roller block, if the lifter bores are taller and machined flat along with three raised bolt bosses for a lifter spider in the lifter galley then you wont have to "retro-fit" in a roller
I do know that it came with the swirl port heads out of a factory 350
Old Feb 26, 2008 | 11:09 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
A 638 block is a factory roller block.
Old Feb 26, 2008 | 10:54 PM
ljnowell's Avatar
yeah, but whether or not its set up, is left to be determined.
1992 Trans Am
May 10, 2023 07:19 PM
fasteddi
Sep 2, 2015 10:29 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
