V6 to V8 Swap
V6 to V8 Swap
I have an 88 RS that I am almost finished putting a 305 in. I may be able to get a souped up 350 now instead. My question is, what else should I change out to help support the extra power. I have a 700r4 that came with my 305 and the rearend is still stock. All front suspensions is still stock. Any advice would be greatly appreciated. My goal is to have a car that can really move without spending a ton of money. (I believe we all share that common goal)
This V6 camaro has a very straight body and the doors open and close so smoothly.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Step one is to install subframe connectors. That will keep your doors opening and closing smoothly.
Poly suspension bushings and engine mounts are always a good idea.
The TH700 will probably need some beefing up. The Transmission and Drivetrain forum discusses that regularly.
Hello, Michael
Aug 20, 2015 03:19 PM
