LO3-LB9??????
Old Mar 3, 2008 | 11:34 AM
jeepboy180's Avatar
Car: 92' RS 25Th Anniversary
Engine: 305ci TBI
Axle/Gears: 10 bolt limited slip.
LO3-LB9??????
Whats all involved when goin form TBI to TPI???? I like the 305ci, but I want to get the most out of it. What do I have to change? The heads, computer,etc???
Old Mar 3, 2008 | 11:41 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: LO3-LB9??????
Heads, camshaft, intake manifold, exhaust system complete (from the manifolds to the cat-back), ECM, engine harness (or modify yours), fuel pump, air filter housing and plumbing...
It can be done, but you need everything. If you can find a complete wrecked car, that's the easiest way. Next, is making a long list, checking it twice, and hitting the classifieds here, wrecking yards, craigslist, eBay, etc...
It's been done, so don't give up!
Good luck!
Old Mar 3, 2008 | 11:49 AM
jeepboy180's Avatar
Engine: 305ci TBI
Re: LO3-LB9??????
Thanks, Ill post as I go.
