305tbi to 350 carb how much $$$$$$$
Old Mar 9, 2008 | 02:48 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok this is what i want!
350
valves 2.02 1.6 at least
compression at least at 11
800cfm carb at least
it will be a dual plane intake
large tube headers with muffler
high performance roller cam with at 550in lift for the Int and Exh at least
and should be making 450-470 hp with 430-450 tq
How much will this cost to be built and installed?
Old Mar 9, 2008 | 09:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Research summitracing.com, jegs.com, eBay, craigslist, etc., for the prices of the parts. Plan on spending at least as much as what you come up with for parts to cover labor. Maybe more since you're doing a customized swap (in the shop's mind).
Old Mar 25, 2008 | 02:36 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: 305tbi to 350 carb how much $$$$$$$
Parts of this combo are overkill.
350
11:1
185 cc AFR Eliminator heads
670 Holley Street Avenger
Edelbrock dual plane
xr282hr cam .510/.520 lift
about 450-460 hp
at 10.4 comp and vortech heads, that combo gave me 426 hp, and 436 lbs of torque. runs a lot stronger with the afr's
Old Mar 25, 2008 | 03:18 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Check out Competition Products at http://www.competitionproducts.com/
Order one of their great catalogs and price it for yourself. Or, call them and see what they can do for you.
Good luck
Old Mar 26, 2008 | 07:04 PM
90rs350crate's Avatar
Car: 90 rs
Engine: 330 hp crate 350
Transmission: stock
350
11:1
about 450-460 hp
so you gained an extra 10 hp off the AFR's? do you think it's worth swapping from vortecs to the AFR's.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theurge
Aug 21, 2015 12:46 PM
armybyrd
Aug 10, 2015 09:23 PM
