New engine rebuild
Old May 1, 2007 | 09:26 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
New engine rebuild
ok, just got car back and running after much drama. Just talked to shop and they said motor needs to run then valves adjusted. One how to I break in engine. Two, after breaking in do valve normally need ajusting. Three, how do you adjust these.
Old May 1, 2007 | 11:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Break in is a pretty subjective topic. GM has a recommended procedure that involve easy driving for 50 miles, then mild acceleration to about 50 MPH, slowing down, repeated 10 times, then moderate acceleration repeated 10 times, then oil change. How much difference does it make? Probably not a lot. The most important part is to use petroleum-based oil during the period, not abuse it, and drain the oil after cam break-in (hopefully that has already been done) and after about 500 miles.
Re-adjusting hydraulic lifters is pretty much an exercise in over-caution. Basically you loosen the rocker, re-tighten it until all "lash" is gone, then tighten 1/2 turn more. You can either do this while the lifter is on the "heal" of the lobe, or while the engine is idling.
Old May 1, 2007 | 12:15 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Re: New engine rebuild
stupid question, during idle, will i have problem with spillage of oil?
Old Mar 26, 2008 | 09:16 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
Yes the oil was shooting over my fender today
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
