I am gonna catch hell for this
Old Apr 12, 2008 | 01:54 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have a Cosworth vega engine and I know those engines can get to 200hp with very little work and 280hp is easy and keep it streetable and these are wheel numbers. But I have a 78 monza S(77 vega) and I have done full suspension but the body has severe rust as most do but it is repairable. I have thought of building the engine and putting it in the camaro but how much does a camaro weigh with out the 305 and with the T5. If the car is still over 2500 I most likely keep the engine for my monza but it is tempting to put a 280hp engine with a 9k rev limit and the engine will weigh at most 250lbs. Would it be worth it considering the 3$+ a gallon and the price keeps going up?
Old Apr 12, 2008 | 04:09 PM
ssean92's Avatar
Car: sold
Re: I am gonna catch hell for this
I would have to say that 4 banger isnt much lighter then the 6. so I would have to say unless you have a base model it will weight mor then that
Old Apr 12, 2008 | 04:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like a lot of work for only 280 HP.
Old Apr 16, 2008 | 03:00 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
My '91 formula.... 3,420 with driver when I got it. It's on a diet now, but still over 3,000. My '89 rs.... 2,880 Stripped to only the essientials. I think the engine run about 380-400 lbs. Much heavier than the monza. Besides, how often do you see a monza anymore? I have only seen 2 or 3 in the last year.
Old Apr 20, 2008 | 04:09 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
I say do it (anybody who knows me just rolled their eyes and said, "here we go again...) since you have all of the parts. Monzas, and every other H body from that vintage, are getting rare to find. Your Vega engine should have a chevy rwd bolt pattern so the trans won't be a problem.
Worst case scenario, it sucks, then you pull it out and put it in a Chevette or an early 80's S10. Best case, you get a unique ride with decent mileage. Either way, you still win.
Good luck.
Old Apr 20, 2008 | 08:36 AM
BAD INTENTIONS's Avatar
Car: 1991 Chevy Camaro...
Engine: 406 With Many Mods..
Transmission: Turbo 350...Hurst Quarter Stick...
Axle/Gears: 373 Gear..Posi Rear End...
It seems like a lot to go through for that amount of HP...However if ya wanna do it I say GO FOR IT...Ya never know what it may become...
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
91 SrS
Oct 7, 2015 04:32 PM
aaron7
Sep 30, 2015 09:15 AM
