will i blow my fuel pump or regulator up?
Old Apr 14, 2008 | 02:24 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I traded my buddy my efi setup for his carb setup. We kept the pumps though, but he gave me his regulator and gave him mine. My question is will I be able to run my walbro on that afpr and lower it enough? T
The regulator has a return line so thats not an issue.
Old Apr 14, 2008 | 12:09 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: will i blow my fuel pump or regulator up?
you can run your with a bypass regulator that the kink that has a return port to go back to the tank but make sure its for the high press and take it down to about 15psi or swap in a tbi pump for the same type of regulator for the lower press setup then just use the second regulator to take it down to the 5-7 psi a carb works at. Your buddy on the other hand has no choise but to swap in a high press pump for the tpi setup.
Old Apr 14, 2008 | 09:28 PM
ljnowell's Avatar
If you have an adjustable regulator with a return line you should not have to fool around with two seperate regulators as posted above. Just set it for the right fuel pressure and plumb everything properly.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
