455 Buick BBC bolt up to any firebird/camaro?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 455 Buick BBC bolt up to any firebird/camaro?
A Buick has the same bellhousing bolt pattern as Oldsmobiles, Pontiacs and Caddys. Small and Big block Chev's have their own bolt patterns.
A Buick isn't a BBC.
To use any of the BOP engines, you need a transmission with the proper bellhousing bolt pattern. After that it's just the typical swap issues such as engine mounts, exhaust etc.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
BBC = big block Chevy
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You should search for postings from a guy named "Magilla" because he did it. He put a 455 Buick in an 87 T/A. It even made Hot Rod Magazine...
Good luck!
Good luck!
Car: '91 Trans Am GTA / '83 Camaro
Engine: 383 SBC / 430 Buick BB
Transmission: Tremec TR-3550 / TH-400
Axle/Gears: Stock 10-bolt, 3.42 /10-bolt
I also have a big block buick in my '83 camaro. I used a 430. I put it in along with the mating buick TH-400. I did the install a while back(~2002) and it's just been sitting since. I've been collecting some more parts for it and need to get back to it! I think one of the first parts I want to add in is a spohn torque arm and trans crossmember for a th-400.
I have a few pictures here:
http://www.geocities.com/mustang732/images/430inCamaro/
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I have the article about magilla's car. At the time of the feature, he was using stock exhaust manifolds. To use the factory torque arm setup, he used an adapter to a 700R-4. If you go to an aftermarket torque arm setup, then you could use a 200-4R. If you want a manual trans, you're just about locked into either using the adapter plate between your Buick block and a Chevy trans, or else doing a custom hydraulic clutch release setup.
McLeod makes a few bellhousings for the BB-buick for adapting other transmissions to it.
This particular one is for mating a T-56 to a BB-buick:
Link
Link
Engine: 2.8/TBI/TPI
Yep, I have my eye on that McLeod bellhousing for my Pontiac V8 third gen. I have to run my beefed up 5 speed so it seems like a nice fit.
I guess we have to make a slave cylinder bracket to run it, but that shouldn't be too bad.
I'll post pics when I get the setup working, it will be a while because I am still deployed...
Good luck on the 430 Camaro! I have run a few 430 engines and they are not too bad at all. I do recommend plugging the oil holes in the block that feed the cylinder heads and then the valve train and using 70-76 455 lifters and hollow pushrods. That seems to oil the top end better. Also don't forget to do the front cam bearing mod! I have already destroyed one Buick BB by not knowing what that was!
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 430Camaro
I also have a big block buick in my '83 camaro. I used a 430. I put it in along with the mating buick TH-400. I did the install a while back(~2002) and it's just been sitting since. I've been collecting some more parts for it and need to get back to it! I think one of the first parts I want to add in is a spohn torque arm and trans crossmember for a th-400. I have a few pictures here:
Way ahead of ya...
(although I've decided to ditch that crazy TB elbow and fab my own.)
Car: 1987 Firebird
Engine: 355
Link
Link
Ive done months and months of research on this, and everything leads back to the keisler conversion package for a TKO transmission. (5spd).
Mating a t56 to a BOP pattern, and getting the hydraulics to work is not hard. But what the heck do you use for a flywheel or clutch? I dont think anyone makes one for the conversion.....
I maybe wrong though as i primarily researched for the LT1 design.... Do you have any insight?
Engine: 2.8/TBI/TPI
McLeod will make the flywheel for 500 bucks. You can use whatever clutch setup you specify, so if you want a BB Buick V8 to run an LT1 clutch, that's what you gotta do.
I had them draw up a 5.7 diesel flywheel for me (since GM wasn't nice enough to do it for me first) and it was a nice piece. Pricey, but nice.
If you're gonna keep the car, this is what you do. If you're building the car to sell, go a different way.
Car: 1987 Firebird
Engine: 355
did you provide them the measurements? Or an engine or anything? Or did you just call em up and asked what you wanted?
I have already sold my buick....
Will get back into one if i can sell my firebird. However, a freind of mine is looking desperately for a transmission that doesnt cost $5000.... He drives an olds.
So would he simply call up McLeod and ask them to make him an LT1/or LS1 T56 flywheel for a McLeod clutch?
As for the "pricey", most flywheels run about $300 or so.
The centerforce conversion peice for the Gen 1 SBC to a T56 originally came about by someone custom ordering it. It cost $500 for the guy who had it custom made for him. Since now that its mass produced because it has become so popular, it still goes for about $420.... As i found out with my T56 conversion.
So for an olds or a buick custom flywheel being $500, thats a pretty good deal
Will get back into one if i can sell my firebird. However, a freind of mine is looking desperately for a transmission that doesnt cost $5000.... He drives an olds.So would he simply call up McLeod and ask them to make him an LT1/or LS1 T56 flywheel for a McLeod clutch?
. Last edited by online170; Dec 13, 2008 at 06:37 PM.
For the buick flywheel, TA Performance sells flywheels. The one at the bottom of this page says it accepts up to an 11" clutch:
http://www.taperformance.com/search....=&sprice=&pg=2
So the only other thing to worry about would be the pressure plate bolt hole placement.
TA also had some lighter weight aluminum flywheels.
Engine: 2.8/TBI/TPI
I had to mail them my old automatic flexplate so that they had a reference for the right ring gear and balance weights; they made the new manual trans flywheel for the clutch pattern I wanted and then put my ring gear on the new flywheel.
I was happy, except for the price! Good workmanship, though.
dimented24x7
Sep 6, 2015 03:51 PM
