A/C wiring help
Old Apr 21, 2008 | 01:44 AM
JODYP1's Avatar
A/C wiring help
I have a 1985 Trans Am. I just swapped in a 1988 Corvette L-98. I have two plugs that went to the trans am a/c containing a total of 4 wires. The corvette a/c only has 1 plug containing 2 wires. Which wires do I need to hook together to make the corvette a/c work?
Thanks all
Old Apr 23, 2008 | 11:55 AM
sngreen's Avatar
Car: 1984 Z28
Engine: 468 Ci
Transmission: T-5 (Until it breaks)
Axle/Gears: 3.73 posi
Re: A/C wiring help
The only wires you really need are the ones that go to the a/c clutch and the clutch cycling switch on the reciver drier. the real easy fix would be to reuse the old a/c stuff of the trans/am. because i belive the compressors are different, so without some extensive wiring mods. it would just be alot more easy to just reuse your old stuff!
hope this helps!!!
diana227vegas
Jul 8, 2016 12:27 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
zayne0
Aug 24, 2015 07:22 PM
BikeFarm
Aug 11, 2015 11:35 PM
