another 305tbi to 350 carb
Car: 1982 z28
ok none of the other threads directly answer my questions
will a non 3 port fpr work? link can i make a loop in the system to return fuel to the tank?
what clolor wires connect to where on the hei distributer?
how do i hook the tv cable up to a carb?
im useing a 350tbi motor from a cadilac fleetwood, but im puttign a perfromer and a 650 holly on it along with different heads and some roller rockers and a
cam
cam
Transmission: 4L80E/4L80E
Nothing new here, but let's give it a shot:
The in-tank electric pump needs a constant flow, which is accomplished by the factory fuel pressure regulator return. If you use a non-return regulator, you have to apply some sort of flow restriction to the return. You can do that with something like a needle valve in the return line that maintains minimum fuel pressure under maximum engine demand, but it's a bit of a trial & error process. A return-style regulator makes it a simple process.
You need the wires currently going to the coil hooked up to a coil-in-cap HEI distributor. The pink wire is the ignition-switched power, the white wire is the tach sensor wire.
Get a corrector bracket that attaches to the throttle arm for the TV cable. Search summitracing.com, jegs.com, etc.
Car: 1982 z28
Re: another 305tbi to 350 carb
ok, i have a carb setup tank that im going to use the sending unit outof and go with a mech pump so the fuel issue is solved now. nut does the tv cable have to be pulled when the throttle is? how does that work
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
