350 engine question
Old May 11, 2008 | 05:41 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
350 engine question
I have a 10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal engine with 14102193...87-up...305/350......1.94"/1.5" valves heads and I want to know more about this engine as i am stuck with it for a few reasons. I have found out that this is supposed to be a crate engine from gm but it has truck tbi heads and not vortec heads as i originally thought. What would be the most reasonable way to swap out my old 305?? here is a parts list i came up with
Camaro parts list
1.350 engine with truck tbi heads
2.350 tbi unit
3. Not sure what cam
4. Full mac exhaust here weld metal EGR pipe to exhaust 844.00
5. Fuel pressure adjuster spring here 23.00 shipped
6. Better fuel pump here 100.00 shipped
7. 350 Electronic spark control here 75.00
8. B&M tork master torque converter
9. Rearend posi drum/disc 3.73 here 250
10. Tbi chips custom tune 100-300 here
All i need is some kind of cam that will work with the tbi heads to get at least 350 horsepower if that isnt possible than what heads can i get cheap to reach my goal? thanks in advance
Old May 12, 2008 | 02:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A reasonable cam would be a LT1 take-out cam. You won't get to 350 HP with those heads, but certainly better than the 170 you've got now - perhaps 250-275.
Your link for the exhaust just goes to a "shopping cart" page. Worked for you, won't work for us.
Reasonable heads to support the ZZ4 cam would be http://www.sdparts.com/product/SD806...keHeaders.aspx . Not sure about the 350 HP part, but you'd be a lot closer.
Old May 12, 2008 | 06:46 PM
Car: Camaro RS
Re: 350 engine question
Sorry about the link its a full mac exhaust. Ive decided to go with the vortec 062 heads and a Comp cams CC305 7-305-8 here what valve springs and retainers do you recommend with this setup? how much hp and tq will i be close to?
Old May 12, 2008 | 08:48 PM
five7kid's Avatar
Where are you getting the heads? If they are JY heads, you'll have to have them modified to handle that much lift. The ones from SD Parts I listed come ready for either cam.
Old May 12, 2008 | 09:04 PM
Car: Camaro RS
he problem with that is i am running tbi not carb and if i do get the carb to tbi adapter i will need a new hood. what modifications do i need to do?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
