suggestions
Old Jun 6, 2008 | 09:58 PM
Jaybo_is_god's Avatar
suggestions
well, i stripped the bolts on the flywheel anyone have any suggestions on how to get them off?
Old Jun 6, 2008 | 10:02 PM
afida15's Avatar
Re: suggestions
you can get these things called stripped nut and bolt sockets i think thats what there called. but you can find them at advanced auto and other auto part stores. they are a great thing to have around the house. just go to the auto parts store and tell them you need something to get a stripped bolt out and theyl find it for you.
Old Jun 8, 2008 | 10:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: suggestions
Flywheel to crankshaft bolts?
Engine in the car?
How did you manage to strip those?!?
Heat it up with a propane torch, then hit it with an upside-down can of compressed air. It probably has red loctite on it. After you do that, heat it up, and use a small pipe wrench on the bolt. Once you get it moving you'll be able to use vice grips.
Old Jun 9, 2008 | 01:52 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: suggestions
I destroyed a bolt on my 2002 dodge ram drive shaft flange(like 15mm if I remember right, maybe 17mm) that had a ungodley amount of loc-tite on it from the factory. I was about to try and drill them out when I bought a bolt and nut remover socket set like afida15 is talking about. I was shocked on how well they worked! Saved me a huge headache. I haven't need them again, yet, but I am really happy I bought them.
If what sonix is saying doesn't work, try doing the same thing with a manual impact socket adapter with the stripped bolt remover socket. Did that make sense? Hammering the manual impact should knock the loc-tite loose.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
