what can i use from 94 Z28
Old Jun 29, 2008 | 04:27 PM
FireTurdWS626's Avatar
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
Hey guy i have an 88 firebird with a 305tbi, and i just bought a 94 z28 with a lt1 and 6-speed, planning on throwing this drive train into my 88, what else would i be able to use from this car? rear axle? front brakes?
Old Jun 29, 2008 | 04:39 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Re: what can i use from 94 Z28
tear the rear end out, get new gears... 3.73, 4.10s.. whatever you want, do the rear while its out, then swap that into your 88. It fits right in. Use the drive shaft from your Z, that works too. the only thing with ur rear the E brake cables you'll have to modify to get them to work. You can use the springs if you want too.
Old Jun 29, 2008 | 07:45 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
You can use interior also. You can use the rear end IIRC some said it sticks out a couple inches.
Old Jun 29, 2008 | 09:24 PM
86LT1's Avatar
Engine: 357 LTx
yea like chevyowner02 said, the seats will go right in place of the original seats, and when i did my rear swap into my iroc i believe when i measured it, it turned out to be about 3-1/2" wider than the stock rearend in your 88'. with the original wheels on it makes the rear tires flush with the rear fender flares... maybe just a hair bigger. But it looks good. unfortunetly i do not have a pic of it on here right now or i would post it to show u.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
