86 iroc 305 swap for 350
Old Jun 29, 2008 | 11:07 PM
nickle005's Avatar
I have recentley aquired an 86 iroc-z with a 305 and planed on puting in a 350 but have herd that the computer would need changed to a 350 computer or it wouldnt idle right is this true?
any ino would be helpful on this matter thanx!
Old Jun 29, 2008 | 11:18 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Re: 86 iroc 305 swap for 350
you just need to chip it... or re program it.... OR! you can just toss a carb on it and not worry about the computer.. thats wat i did
Old Jun 29, 2008 | 11:21 PM
nickle005's Avatar
would like to keep the Tpi, so were would one get a chip ?
Old Jun 29, 2008 | 11:22 PM
that i don't know.. search around on the forums you'll definitely get your answer. sorry can't be more help
Old Jul 1, 2008 | 06:31 PM
tilerob79's Avatar
Car: 1990 Camaro RS
Transmission: automatic
daghstdrummer so how is that carb setup working for you. What did you have before it TBI. What motor did you put in your car
Old Jul 2, 2008 | 11:52 AM
I did have a tbi before, i took the harness out and computer and only left the wires for needed for the starter and distributor.. i ran all new gauges and wiring for the gauges as well as fan wiring (since it was all computer controlled to begin with) the carb setup works great i dropped in a 010 block bored .30 over with a summit bang for buck kit and rebuilt stock heads with 1.6 roller rockers... the motor has power and its fun to drive.. i am still tweaking it little by little.
Old Jul 2, 2008 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '86 TPI system is MAF, which isn't that sensitive the displacement changes. The '87-'88 350 TPI did have a different PROM ('89 eliminated the cold start injector), which helped get a little more power out of it vs. the 305 tuning, but it isn't necessary just to get it to run, or run well. But, you could replace the PROM with an '87-'88 L98 chip, and that would take care of it.
You should change the injectors from the 19 lb 305 pieces to 22 lb 350 injectors. Whether you need to change the knock sensor isn't as clear.
'86 also was the last year for the intake mount bolts all at 90 degrees (except Vette L98's maintained that bolt pattern). If your 350 has '87-later heads, the TPI base won't fit without modifying those bolt holes.
Frozer!!!
Jan 19, 2024 04:55 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
