Doing a V6 to V8 Swap
Old Jul 1, 2008 | 07:15 AM
suade82's Avatar
I have already read above and just have a couple of questions.
I have a 89 RS with the 2.8 and automatic.
I am putting in a low power SBC with and T5. I know this isnt the best thing to do, but I am on a budget and these are the free parts I have laying around and I just want something to cruise around in.
Here is the problem, I have a T5 from a V6, I know I need a new bellhousing, but what do I need as far as a clutch, flywheel, and pressure plate? I know the clutch need to have the correct spline.
Also, will I have the move the motor mounts?
Old Jul 1, 2008 | 08:19 AM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
Re: Doing a V6 to V8 Swap
you will need a T-5 from a v8 because the shaft is different I believe.
Old Jul 1, 2008 | 02:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have heard you can use an S-10 4.3 clutch disk with a V8 pressure plate. But, understand the V6 T5 is very weak because of the small input shaft (among other things).
You have to move the motor mounts on the front cross member.
Old Jul 1, 2008 | 02:33 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
i've heard that v6 trans will work... but save yourself the trouble, it will NOT withstand that v8 for long... just trade it for a v8 trans
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
