400 sbc
Old Jul 13, 2008 | 02:11 AM
snake70's Avatar
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
400 sbc
what needs to be done to use a 400sbc with a standard tranny ...t56? t5?
Old Jul 13, 2008 | 02:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 400 sbc
If you're using a 153 tooth flywheel, you'll probably need to drill and tap the missing starter hole, but apart from that just bolt up the right externally balanced flywheel and go.
Old Jul 13, 2008 | 09:10 PM
snake70's Avatar
Axle/Gears: 308 373
Re: 400 sbc
thats it wow thank you i was it was involved and expensive due to 400 werent standard from the factory. i thought imight get some realy answers on here
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
