350 fuel injec. to carb
Old Jul 23, 2008 | 08:37 PM
bark3rk20's Avatar
Car: 1985 Camaro z28 Iroc-z
Engine: Sbc 350
Transmission: TH-700R4
Axle/Gears: 3:73 gears
I just bought my first v8 car and its an 85 Iroc camaro and was wanting to do a 350 swap in it since it adds more hp and i hear its pretty simple swap. My question is this: My friend said hed sell me his 94 350 for 250 bucks but its fuel injected, so what would I have to do to make the motor carburated and work with my camaro??? do you think it would be easier if i bought an older 350 and just rebuild???
Old Jul 24, 2008 | 11:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 350 fuel injec. to carb
The engine doesnt care whats on top of it, as long as it bolts together. '87 and up will have different bolt hole angles in the intake manifold. You can get a carb manifold for the newer bolt angles no problem.
Old Jul 26, 2008 | 01:12 PM
bark3rk20's Avatar
Engine: Sbc 350
I was told you needed to do a lot of machine work to make a fuel injected motor into a carbd somthing to do with having to machine a hole for the manual fuel or oil pump???? I cant remember which... so if thats not true all I need is a carb manifold with bolt angles for the 94 motor and thats all??? no other prep??? or would I have to run a drop in fuel pump into the fuel tank??
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
