406 in a 92 camaro
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
406 in a 92 camaro
im in the process of building a 406 for my tpi 92 camaro i plan on useing a zz4 cam and zz4 heads is this a good combo thanks.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 406 in a 92 camaro
ZZ4 cam & heads are small for a 406.
Just my 2 cents.
Just my 2 cents.
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
I would research alot of options for that 406 with tpi. You may not like what you find out. A stock tpi on a healthy 406 is not a very good match at all. the zz4 heads and cam are not good for a 406. A set of vortecs may even be too small for that ci. or at a minimum size itleast. The vortecs are probably a 40hp increase over the zz4 heads. Those heads and cam are not anything above average on a 350 but probably reliable though.
Car: 92 Camaro RS
alright i just wanted some input of what everyone thought, and i guess im just going to build me a 350 with the zz4 heads and cam.does that sound like a better setup?thanks guys
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Cam is too small - a roller with lots of lift and say 225/235 split duration would haul ***. Easy 450hp with perfect street manners.
84z96L31vortec
Aug 20, 2017 12:16 AM
