How much would you pay?
Old Aug 4, 2008 | 12:07 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok guys i figuered in 8 to 12 months i will be ready for a new engine! I am planning on a 350 or a 350 made into a 383 stroker. I am wanting to have 400 hp to the rear wheels. So i was thinking around 450-475 at the crank. Now i was planning on around 6,000 am i in the right ball park with this price or should i be paying more or less? I will be having a local performance shop doing it for me.
thanks
kevin
Old Aug 4, 2008 | 07:46 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: How much would you pay?
Any reason you don't want to buy a new crate engine? Only reason I had a shop build mine was for the forced induction. Otherwise I would have saved some money and bought a complete engine.
Old Aug 4, 2008 | 08:09 AM
thewolf's Avatar
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
Sounds reasonable, but maybe on the light side for a turn-key custom 383 from a performance shop. The ZZ383 is about $5100 for what is essentially a crate long block. You would need an intake manifold, carb, water pump, and a few other items to make it work. It's the small stuff like bolts and brackets that nickel and dime you as a restoration project goes along. Super Chevy did a budget 383 stroker build, I think they spent about $5k but did much of the work themselves. Here it is.
If it were me, and $6k was the budget, I'd look at a crate 350 and get quotes for installing it. Not only would it be much faster than the stock 305, you could upgrade a few components down the road as you get money for them (manifold, cam, etc.). The GM 350 HO is 330hp/380tq and $2660 from Summit (long block only).
ZEEYAA
Apr 16, 2023 08:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ronscott80
Interior Parts Wanted
Oct 13, 2015 12:26 AM
Royal_Z
Sep 30, 2015 08:45 PM
