86 TPI into 85 Carb camaro wiring issues
Old Aug 4, 2008 | 07:11 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
Has anyone ever put a TPI in a Carb Camaro still retaining the Carb Dash harness. I wondering what the main differences there are in the wireing that hooks the Dash wiring to the Engine/ECU harness.
I can't find an exploded view of the connectors on the dash side of the 85 carb v8 that plug into the Engine management harness connector. If I had that I would know where the wires went.
I'm putting an 86 TPI into a 85 camaro with the 86 ECU harness. Basically the driverside of the car has the harness that runs the starter, AC, Distributor, and brakes. The passenger side is just Engine Management from the ECU.
( I have an 88 ECU harness and it runs from both sides)
I've got most of the info I need on the 86 harness but just about no information on the 85 dash harness.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
stalkier
Aug 7, 2015 04:49 AM
