383 Build Up
Old Aug 18, 2008 | 12:18 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
383 Build Up
I just bought an L98 that came out of a 91 GTA. The guy I bought it from had alot of head work done to the motor including, porting the hell out of the heads, and adding roller rockers with dual springs. The motor has a Comp 306 cam in it. 112 LSA, 229/245. I've heard that this cam can be a bit much for a 350, so I want to go with a 383. Anyone have any recommendations? Should I go with flat top pistons, inverted dome? I'm trying not to spend a ton of money on the rotating assm. The top of the motor has about 5K on it, and the bottom has about 120K. So, I might as well replace the bottom end.
Also, I plan on using the stock throttle body and TPI intake out of my 87 Trans Am. I'll probably port the upper plenum the best I can to get a little more flow out of it.
Last edited by Hello, Michael; Aug 18, 2008 at 12:21 PM. Reason: Automerged Doublepost
Old Aug 18, 2008 | 01:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The problem isn't "350 cubic inches", it's "stock TPI".
I'd also classify this, "porting the hell out of the heads", as a "worry item".
Old Aug 18, 2008 | 06:31 PM
Engine: SBC 350
Re: 383 Build Up
The heads were ported, and milled 0.080. The spring seats were also cut to fit larger/dual springs, and Manley valves were installed in addition to the roller rockers.
Could you "splain" please about your last reply, five7kid?
Last edited by Hello, Michael; Aug 18, 2008 at 06:34 PM. Reason: Automerged Doublepost
Old Aug 18, 2008 | 11:39 PM
five7kid's Avatar
Hogging out iron from the ports is just as likely to hurt flow and performance as it is to improve it. Basic clean-up and smoothing is more effective than taking out a lot of material.
Old Aug 19, 2008 | 11:11 AM
Engine: SBC 350
Re: 383 Build Up
Im unsure as to how much porting was done. The porting work looks very good on the heads.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
83RDRACR
Mar 26, 2016 08:13 PM
Jorlain
Oct 8, 2015 01:57 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
