LT1 swap VATS Question?
Old Aug 30, 2008 | 05:08 PM
purpleZ28's Avatar
Car: 88 TRANS AM
Engine: 5.7 LT1
Hello guys im new to this site and have a couple questions about the vats system on my car its a 92 z28 i recently put an lt1 from a 95 z28 in it with a T56 trans i used a underhood fuse relay box harness and pcm from a 94 z28. I was wondering if i have to bypass vats or if i can keep it bc the engine wont crank and the fuel pump wont prime when you turn the key on. I was looking at some diagrams and found 2 wires on the c207 wht/blk ignition key resistor feed and ppl/wht ignition key resistor return if anyone can help it would be greatly appreciated.
Old Aug 30, 2008 | 06:12 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: LT1 swap VATS Question?
You have to address vats or your car will not run.
That being said, most people have it tuned out of the pcm. You can bypass vats, or there are ways of keeping it if you really want it. Do a search on here it has been covered many times.
Old Aug 30, 2008 | 06:17 PM
BCdawg57's Avatar
Keeping vats:
https://www.thirdgen.org/forums/ltx-...highlight=vats
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
