efi to fully mechanical carbed 388
Old Sep 4, 2008 | 11:14 PM
86ta388stroker's Avatar
yea im swapping the old 305 tpi to a new 388 stroker in my 86' ta what has to be done for this swap
Old Sep 4, 2008 | 11:24 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: efi to fully mechanical carbed 388
Fuel pump will supply too much pressure. May be able to just put on a pressure regulator, or get a pump made for a carb. New motor needs an old style HEI dist. that can run without a computer. That's all the major stuff I can think of, but there's other minor things like the throttle cable and trans. cable.
Old Sep 5, 2008 | 12:27 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
this has got to be in the top 10 most asked questions do us all a favor and search. thats what the feature is for...there are also a cpl write ups IIRC ...look around........then when u get stuck as a question....
Old Sep 5, 2008 | 01:25 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
But to sum up what you need - 3 port return style regulator, non computer controlled carb, non computer controlled dist such as a vaccum advance. That's it.
Old Sep 9, 2008 | 07:40 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I just swap a carbed 35 into my cfi 82 camaro so if you have any specific questions pm me and I will see if I can help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jtwoods4
Sep 3, 2015 05:39 PM
willyjoejr
Sep 3, 2015 09:26 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
