can I just pull everything from a wrecked 91 350 tbi truck with manual transmission, computer, harness, chip and so and use in my 91 tbi 5.0tbi camaro with manual trans. with using the 350 from the truck. will just replace normal gaskets, complete tuneup, oil change and put the 305 exhaust manifolds on the 350. everything else is the same except exhaust manifolds. Does anyone see any problems
I would recommend using the harness and compter from the car. You will need a burned chip for it. You can get that from tbichips.com or numerous others. And I would really recommend getting headers and better exhaust. The exhaust is already restrictive for a 305, and you're adding more.
