v8 to v6
Old Sep 12, 2008 | 04:50 PM
orangemonster's Avatar
Car: 1986 IROC 305 TPI
Engine: 1989 RS
Transmission: 5 speed
Axle/Gears: 3.08
v8 to v6
I have an '89 camaro with a shot 305 in it and a T5 manual. I want to put the 3.1 v6 in its place. I wanted to know what is different and the same. I know I need the computer and all attached wires from the v6 but are there any commonly forgotten wires usually left out. Does the manual have a removable bellhousing. Anything in the car, like the fuse box, that needs to be changed. Any help would be greatly appreciated. Thanks.
Old Sep 12, 2008 | 04:53 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: v8 to v6
youll prolly need a v6 tranny and pretty much everything like ecu and all harness and such. Why do you want a 6 in stead of a 8???
Old Sep 12, 2008 | 05:36 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: v8 to v6
X2, Why are you switching to a v6?
Old Sep 13, 2008 | 12:28 PM
92_LT1's Avatar
Car: 1992 Camaro RS
Engine: 355ci LTx / 500hp
Transmission: G-force T56
Axle/Gears: 3.73:1
Re: v8 to v6
At least, why the 3.1? Go for the 3.8L with 200 stock horsepower!
Old Sep 13, 2008 | 07:05 PM
Engine: 1989 RS
Axle/Gears: 3.08
Re: v8 to v6
I already have a camaro with a v8 so I thought of putting a v6 in the other for the efficency. 3800 would be too far beyond my scope/time limit but instead of a 3.1 what about a 4.3?
Old Sep 13, 2008 | 07:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: v8 to v6
Don't waste time with the 4.3... you might as well stay with the V8 if you do. The 4.3 is a pig on gas - as bad or worse than the V8 cars ever were, and you'd be down all the V8 power and torque.
If you change to a V6, I'd second the 3800 idea - find one out of a 4thgen and then you'd be set. Same-ish mileage as the 3rdgen V6s, but twice the power and just an overall better engine. I wonder if the supercharger from the GTP would work too....?
Old Sep 14, 2008 | 09:56 AM
92_LT1's Avatar
Car: 1992 Camaro RS
Axle/Gears: 3.73:1
Re: v8 to v6
The eaton M90 from the GTP can be made to fit, but the biggest difficulty would be the elbow for the intake that faces the rear of the engine.
If you really got determined to use a stock 3800 blower, you could always order an Australian M90 with the elbow that's set up for their rear wheel drive cars! They know it as the 3.8L ecotec motor.
The best 3800 option though, as far as forced induction goes, is turbo. There's a guy running 8s with a 3800 series II twin turbo in a 4th gen Firebird, and there are several guys running over 500RWHP on that engine.
The 4.3L shares alot of internals with the 350, but as far as power and gas mileage goes, it's a dog. If you want a truck motor and want to stay 6 cylinder, do an LL8 inline 6 from an Trailblazer. 291HP stock for 05+ out of that 4200 Vortec. That'd be an animal in a 3rd gen!
