POWER STEERING PIPE QUESTION ??????? WORRIED ABOUT
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
my car was a 2.8 v6 but i baught it with a 350 v8 (1989 rs)
my question is that i have the pressure pipe of the power steering pump equipped with a type of switch or sensor connected with 2 wires!!
what is that for??? because the switch or ?? is leaking oil and as i have also the pipe broken and also leaking i was going to make one locally because i dont know which pipe i have to order as i saw several part numbers and not sure which one to buy as none of them mentioned the switch or sensor!!!
thanks for the answers in advance
Lorry
Lorry
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: POWER STEERING PIPE QUESTION ??????? WORRIED ABOUT
Lorry
Lorry
I got a hose for an 87 tpi car and fit just like the old one.
I don't know what kind of eng. setup ur using,but that should give you some
kind of help.
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
[ sorry but you did not answered my question.
what is that switch or sensor for?????????????????
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Low pressure switch. If you have A/C it could be the switch that opens the circuit to the compressor clutch when the power steering pressure gets low. A throttle kicker switch was also installed on some vehicles that raises the idle speed when the pressure gets low.
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
my motor is a 350 tbi and it has the mount for the ac compressor but my car has no a/c and no compressor!!
so should i change my power steering pump to a normal pipe and no low pressure switches?
dont forget that originally my car was a v6
if you are sure
next week will fix the problem
thanks
The switch either went in-line to the compressor or to the ECM to bump idle. You're using neither now and can replace it with a hose without the switch. If the parts store can't pull a switchless hose up for your model try a 85 or earlier carbed V8.
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
thanks naf for all ur help
but i am not going to import any pipes! just go to a shop locally and will make one like i have identically with no switch!
as i am from europe and dont like to but the wrong parts!!
thanks again
thanks again
colton_carlson
Mar 8, 2019 12:21 PM
