hood clearance
hood clearance
hi, im brand new to this site and really brand new to camaros. I Purchased a 1990 iroc z about 3 months ago no motor no trans i started building a 350 and i got a eldebrock preformer rpm intake manifold....i didnt know if that would be too much of a rise for the hood or not. i really dont want to go to a aftermarket hood i like the stock hood on it....also i got one more question about water pump....will i need to run a short shaft?
thank you
jeremy
thank you
jeremy
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: hood clearance
long water water pump and yes it should fit. I run a Performer RPM and a holley and it fits under my stock hood with a drop base air cleaner.
Car: 1982 Z28
Re: hood clearance
I am not sure of the inches but it could drop any more or the lid would be too close to the carb. It has dimples for the holley fuel bowls or it wouldn't even come close to going on all the way. Sorry I cant give you a more accurate measurement right now but if you want I will measure it tomorrow for you. I would say like 3 inches.
If you have any problems getting it running, let me know, mine gave me fits so I might be able to help. It is all still fresh in my mind I put it in a few weeks ago and I just got it running "right" yesterday.
Transmission: 4L80E/4L80E
And, it's not the water pump shaft that is short or long, it's the length from the engine mounting surface to the pulley mounting surface.
Car: 1982 Z28
Re: hood clearance
I guess I assume that everyone has a dinosaur v belt system like me!LOL
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
